fracos
#1 Posted : Monday, February 21, 2011 6:34:29 AM(UTC)
fracos
Washer will go thru entire cycle but timer will continue to run - will not shut off :(
Jeff / APP Team
#2 Posted : Monday, February 21, 2011 7:46:24 AM(UTC)
Jeff / APP Team
Lets check the pressure switch first to make sure it is working properly. Unplug the machine and gain acess to the pressure switch.(water level switch) Unplug the switch and test where the yellow/black wire was to the violet wire was on the switch. With a multi-meter this should read closed continuity. If open you have a bad pressure switch. If closed you have a bad timer. I will list both parts on here for you. Hope this helps.
Part number: AP2045895
GE washer grinding noise (Washer Repair)
by gefixin 5/20/2024 2:01:39 PM(UTC)
GE Washer Topload model I have a GE top load washer GTW750CPL0DG. It fills and it is running but whe (Washer Repair)
by MimiReel 1/28/2024 12:03:27 PM(UTC)
GE washer GTW750CPL0DG (Washer Repair)
by Guest 1/28/2024 11:49:12 AM(UTC)
GE Washer with bad transmission? (Washer Repair)
by fljlee3 1/16/2024 10:50:07 AM(UTC)
GE washer and dryer lost face clothes (Washer Repair)
by chris24681012 12/19/2023 5:44:47 AM(UTC)
GE washer drain problem (Washer Repair)
by gurka75 11/16/2023 10:07:53 AM(UTC)
GE washer model GTWN4250D0WS fill water but will not agitate or spin during wash cycle (Washer Repair)
by Dweynand 8/29/2023 7:01:15 PM(UTC)
GE Washer model GFAN1000L2WW. Stucked during the washing process with no agitation. (Washer Repair)
by Guest 8/24/2023 4:22:18 PM(UTC)
GE Washer GLWN5550D0WW trying to test if the shifter disengage from the wash basket (Washer Repair)
by steveh1776 3/27/2023 6:00:43 AM(UTC)
GE washer will spin but will not agitate on the wash cycle (Washer Repair)
by Jodibrewer2002@yahoo.com 2/14/2023 10:39:58 AM(UTC)
GE WASHER MAKES GOD AWFUL SOUND AFTER FILLING WITH WATER (Washer Repair)
by Guest 2/12/2023 5:04:03 PM(UTC)
GE Washer GTW335ASN1WW (Washer Repair)
by jmulc82189 2/8/2023 10:36:12 AM(UTC)
GE Washer Ending Cycle after abt 3-5 mins (Washer Repair)
by FelixSS 2/6/2023 5:37:03 PM(UTC)
GE washer wbse4220aoww (Washer Repair)
by Guest 9/21/2022 2:04:51 PM(UTC)
GE washer- washes clothes, spins, drains then fills w water again (Washer Repair)
by Skep19 9/19/2022 9:36:54 AM(UTC)
