jasdevgill2
#1 Posted : Tuesday, February 15, 2011 9:49:47 AM(UTC)
jasdevgill2
Compressor is not running. I dont' see any power coming to compressor. What could be the issue with the refrigerator.
Joe / APP Team
#2 Posted : Wednesday, February 16, 2011 8:43:53 AM(UTC)
Joe / APP Team
Jasd,
There are several tests you will need to perform, to properly diagnose the problem.
Your technical data sheet, should be located on the backside of the kickplate grille.
You'd be better able to diagnose the problem,
Is evrything else working properly, the fans are running, lights work and the display is proper ?
If you have a multimeter, you may want to perform the following test at the mother board, so we'll have a better sense of direction to take.
Check for 120VAC at connector J7-9
orange wire to TAB1 / J11 Black wire.
Do you have 120VAC
No
Replace board
I've also attached a copy of a service manual for similar models, it may be helpful, for getting an idea.
Good Luck,
File Attachment(s):
Arctica Profile GE Side-by-Side Refrigerator.pdf (1,717kb) downloaded 24 time(s).
GE Profile Artica (PSS25NGNA) - erratic cooling (Refrigerator & Freezer Repair)
by VentureRider 2/13/2022 6:03:36 AM(UTC)
GE Profile Artica no ice but passes check (Refrigerator & Freezer Repair)
by phatcher 4/1/2020 2:01:31 PM(UTC)
Side by side GE profile Artica won't cool (Refrigerator & Freezer Repair)
by paulbridges 7/20/2014 11:45:20 AM(UTC)
Fan noise on GE Profile Artica? (Refrigerator & Freezer Repair)
by rudybickel 1/26/2014 1:30:16 PM(UTC)
GE Profile Artica Side by Side (Refrigerator & Freezer Repair)
by bssbt676 6/18/2012 10:18:00 AM(UTC)
GE Profile Artica not cooling right (Refrigerator & Freezer Repair)
by cjquik25 6/15/2012 4:12:18 PM(UTC)
GE Profile Artica SxS 00'-01' Yr Quit Cooling (Refrigerator & Freezer Repair)
by CigarDad 3/27/2012 7:44:51 AM(UTC)
GE Profile Artica too cold (Refrigerator & Freezer Repair)
by sharynlee 12/14/2011 1:27:19 PM(UTC)
GE Profile Artica Refrigerator & Freezer won't cool (Refrigerator & Freezer Repair)
by CLDimmick 12/6/2011 2:27:25 PM(UTC)
GE Profile Artica defrost problem? (Refrigerator & Freezer Repair)
Belarus cheryl10 7/31/2011 6:41:15 AM(UTC)
GE Profile Artica Fridge Not Cold Enough & Erratic (Refrigerator & Freezer Repair)
by stevedal 6/12/2011 4:46:16 PM(UTC)
GE Profile Artica has Noisy compressor and Freezer side not freezing cold (Refrigerator & Freezer Repair)
by TechBang! 12/10/2010 9:17:27 AM(UTC)
ge profile artica refrigerator (Refrigerator & Freezer Repair)
by voooooo 1/9/2010 3:28:22 PM(UTC)
GE Profile Artica - frozen food in refrigerator (Refrigerator & Freezer Repair)
by Mikerim 11/28/2009 1:01:46 PM(UTC)
GE Profile Artica ref. (Refrigerator & Freezer Repair)
by pkimbro 11/10/2009 7:58:04 AM(UTC)
