My dishwasher has had a metallic smelll coming from the control panel over the past month. Finally, in the middle of a wash cycle, the machine just stopped like it lost power. The circuit is live and the panel does not respond to any buttons. Any suggestions? Should I replace the control panel fuse and see what happens? How do I tell if it went bad? Thank you.
Originally Posted by: mwonsala My dishwasher has had a metallic smelll coming from the control panel over the past month. Finally, in the middle of a wash cycle, the machine just stopped like it lost power. The circuit is live and the panel does not respond to any buttons. Any suggestions? Should I replace the control panel fuse and see what happens? How do I tell if it went bad? Thank you. M, Based on your post, The control panel fuse would be a good place to start. Part number: AP3178588
If you have a multimeter, you can check for a closed(infinite resistance) circuit across the terminals of the fuse(it is a one shot/ throw away component) before you order and replace the part. But it does sound like it has opened up. :) :) :)
