Trentkc
#1 Posted : Sunday, January 16, 2011 12:18:11 PM(UTC)
Trentkc
I have an 8 year old Frigidaire stove whose oven came on one night and would not turn off.
Pushing the clear/off button has no effect. Also tried setting oven timer and that does not turn it off. It is the bottom oven element only, and it goes red hot. The oven need to be unplugged or oven element stays on high.
I took off the rear panel and looked at connections, all are fine. Also looked at temperature probe and it looked okay. All other functions on the stove operate properly (burners, broiler, clock and timer)
Is this a failed Electronic Oven Control? Any other diagnostics I can try before ordering an expensive electronic part that will probably not be returnable if that unit is not the culprit?
kayakcrzy
#2 Posted : Monday, January 17, 2011 3:25:57 AM(UTC)
kayakcrzy
I would agree. It is the only thing it could be, unless you have Gremlins in the house!!! LOL!! The part # is 316207507 Tom Appliance Educator, Appliance Parts, Washer and Dryer Parts, Refridgerator and Freezer Parts, Stove and Oven Parts
#3 Posted : Monday, January 17, 2011 4:25:39 AM(UTC)
Replacement parts for FRIGIDAIRE FEFL77ASF Frigidaire/electric Range | AppliancePartsPros.com
Here is the wiring diagram
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316255141.pdf
You basically have done the troubleshooting.
The only other way for the element to stay on all the time is if it's were to short to the L1 wire. Which is very unlikely.
You may want to order from AppliancePartsPros as long as you have done some troubleshooting they will allow you to return the part if it does not fix your problem.
See their return policy.
Control Board is Item F20 in Section 1.
If the Overlay is the stick on type you will probably also require it (Item 20A in Section 1)
Gas Oven Will Not Shut Off (Oven Repair (including Ranges and Cooktops))
by gj2001 3/1/2013 2:26:38 PM(UTC)
Oven will not shut off (Oven Repair (including Ranges and Cooktops))
by michael.visconti 8/24/2012 11:42:45 AM(UTC)
top oven will not shut off when temp is reached (Oven Repair (including Ranges and Cooktops))
by eldonmac 8/20/2012 2:24:05 PM(UTC)
Broil Element in Oven Will Not Shut Off (Oven Repair (including Ranges and Cooktops))
by stebbs 10/11/2010 7:11:42 AM(UTC)
by bborgerding 7/26/2010 1:52:26 PM(UTC)
My oven will not shut off (Oven Repair (including Ranges and Cooktops))
by brandielee28 11/27/2009 11:24:16 AM(UTC)
by KayHicks 9/22/2009 10:39:33 AM(UTC)
by michelleedwards 5/29/2009 5:23:10 AM(UTC)
Lower oven will not shut off (Oven Repair (including Ranges and Cooktops))
by Rick Stacy 4/12/2009 7:04:35 AM(UTC)
by jhoium 9/29/2007 8:51:16 AM(UTC)
