2 Pages<12
richappy
#11 Posted : Sunday, October 14, 2007 1:54:38 AM(UTC)
richappy
You should buy th special spanner wrench available at appliance parts pros, and they will have the drive block also.
oldman60
#12 Posted : Thursday, November 1, 2007 10:22:03 PM(UTC)
oldman60
i now understand the clutch operation.it is designed to slip and when worn it slips too easily.you can temp fix by increasing spring pressure by stretching spring slightly about 1/4 inch.also make sure no oil or grease is inside clutch drum.i am now working on finding suitable clutch pad material replacements as they are simply riveted on and can be changed.
richappy
#13 Posted : Friday, November 2, 2007 3:28:55 AM(UTC)
richappy
The clutch assembly is available Pn 285785. Make sure the brake shoes aren't dragging or you will wear the clutch out again. Also the basket drive block is available Pn. 389140
3 year old top loading washer won't spin clothes dry (Washer Repair)
by craig100 3/15/2024 9:35:49 AM(UTC)
Samsung washer won't spin (Washer Repair)
by Guest 1/8/2022 10:56:39 AM(UTC)
Maytag Washer won't spin or complete cycle - FIXED! (Washer Repair)
by jimjokjv 10/1/2021 10:08:04 AM(UTC)
Whirlpool WTW4815EW1 Washer Won't Spin or Agitate (Washer Repair)
by dann1551 4/7/2021 8:42:00 AM(UTC)
Maytag performa washer won't spin. It drains and i can hear the motor but tub appears stuck. (Washer Repair)
by Brittrepairs 12/21/2019 7:47:28 PM(UTC)
Whirlpool LSN2000LW Washer Won't Spin, Buzzes (Washer Repair)
by Robb235 2/21/2019 4:21:02 AM(UTC)
Washer won't spin out. (Washer Repair)
by DJChad818 10/26/2017 9:47:20 AM(UTC)
Washer won't spin (Washer Repair)
by Fingers123 10/22/2017 1:43:41 PM(UTC)
Washer Won't Spin (Washer Repair)
by je00409 9/5/2017 11:00:04 AM(UTC)
Washer won't spin or agitate (Washer Repair)
by dhughes 4/1/2017 10:17:04 AM(UTC)
Whirlpool belt drive washer won't spin. (Washer Repair)
by weswoodallz21 3/21/2017 7:08:08 AM(UTC)
Maytag Washer won't Spin just Hums (Washer Repair)
by bnweth 1/4/2017 8:29:35 PM(UTC)
Whirlpool washer won't spin or drain (Washer Repair)
by ronaldjp1 1/3/2017 2:58:09 PM(UTC)
maytag washer won't spin fast (Washer Repair)
by benp1 12/21/2016 5:14:31 PM(UTC)
by lmhansgen 8/31/2016 10:19:23 AM(UTC)
2 Pages<12
