You should buy th special spanner wrench available at appliance parts pros, and they will have the drive block also.
i now understand the clutch operation.it is designed to slip and when worn it slips too easily.you can temp fix by increasing spring pressure by stretching spring slightly about 1/4 inch.also make sure no oil or grease is inside clutch drum.i am now working on finding suitable clutch pad material replacements as they are simply riveted on and can be changed.
The clutch assembly is available Pn 285785. Make sure the brake shoes aren't dragging or you will wear the clutch out again. Also the basket drive block is available Pn. 389140
