bigworm
#1 Posted : Monday, November 24, 2008 4:13:13 PM(UTC)
bigworm
No Oven Or Broiler Indicator Light , And Elements Wont Heat Up. Help
#2 Posted : Tuesday, November 25, 2008 2:19:25 AM(UTC)
Here is the parts breakdown
Model RF302BXGW0
And a wiring diagram
https://www.servicematters.com/d...0Sheet%20-%203196804.pdf
If by elements you mean the surface elements, the first thing I would check is that you are getting 240 volts. Sometimes a circuit breaker can loose half the line without tripping. Turn it off/on slowly.
If by elements you mean the bake & broil elements I would suspect the thermostat.
