No Oven Or Broiler Indicator Light , And Elements Wont Heat Up. Help
Here is the parts breakdown Model RF302BXGW0And a wiring diagram https://www.servicematters.com/d...0Sheet%20-%203196804.pdf If by elements you mean the surface elements, the first thing I would check is that you are getting 240 volts. Sometimes a circuit breaker can loose half the line without tripping. Turn it off/on slowly. If by elements you mean the bake & broil elements I would suspect the thermostat. |
THIS FORUM IS DEAD!!!!!!! |
