One of the baffles on the inside of the drum is loose, how do I access the outside of the drum to tighten the screws?
Remove the hinge screws and screws opposite side,remove door remove panel, on each upper side under lid remove the 5/16 hex screws and "L" braket lift lid, rotate drum gently so belt doesn't pop off screws will be accessable from top of dryer with lid up
