CharlieHat
#1 Posted : Friday, November 14, 2008 12:28:43 PM(UTC)
CharlieHat
One of the baffles on the inside of the drum is loose, how do I access the outside of the drum to tighten the screws?
v2k04
#2 Posted : Friday, November 14, 2008 5:33:44 PM(UTC)
v2k04
Remove the hinge screws and screws opposite side,remove door remove panel, on each upper side under lid remove the 5/16 hex screws and "L" braket lift lid, rotate drum gently so belt doesn't pop off screws will be accessable from top of dryer with lid up
