heggster111
#1 Posted : Monday, November 10, 2008 3:31:57 PM(UTC)
heggster111
no heat at all checked heater assembly and have continuity on all fuses.
did notice that timer doe's not move but makes a clicking noise.
stumped!
#2 Posted : Tuesday, November 11, 2008 1:20:41 PM(UTC)
Check for 240VAC at the power outlet.
Which cycle did you use?
Here are the break down diagrams for the Maytag dryer Model LDE8624ADE
#3 Posted : Tuesday, November 11, 2008 2:18:31 PM(UTC)
The below may help
http://www.servicematters.com/m...ibrary/docs/16008714.pdf
Has a better wiring diagram. Using it and the timing diagram you should be able to troubleshoot the unit a little further suing different cycle types.
Try to get it running on timed dry, it looks like this does not use the electronic control.
I would get my meter and measure across the timer motor windings.
If you see 120 volts but the timer does not advance, the timer needs replacing. Clicking might be a stripped timer gear.
Can also unplug the unit and check that the proper timer contacts close at the different settings.
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
no heat from oven or broiler (Oven Repair (including Ranges and Cooktops))
by lennyag 1/5/2024 1:41:07 PM(UTC)
Dryer loud squeaking and no heat (Dryer Repair)
by hackerfam 11/2/2023 10:52:15 AM(UTC)
LG Dryer DLE2301R No Heat (Dryer Repair)
by mhess01 10/19/2023 4:56:37 PM(UTC)
No heat when assembled (Dryer Repair)
by Guest 8/16/2023 3:44:03 AM(UTC)
whirlpool PN# W10339417; no heating after replacing element (Oven Repair (including Ranges and Cooktops))
by Guest 7/13/2023 12:27:07 PM(UTC)
Whirlpool Duet Electric dryer - no heat (Dryer Repair)
by ShawnDS24 2/25/2023 9:08:24 AM(UTC)
No heat, (Dryer Repair)
by tseibring 1/8/2023 7:57:44 AM(UTC)
Brand New LG gas dryer , GAS code, no heat (Dryer Repair)
by lglad 11/24/2022 7:24:02 PM(UTC)
Gas Dryer GE GFDS355GL0MS No Heat. Ignitor is good E11 error. (Dryer Repair)
by jim.starzynski@gmail.com 7/5/2022 6:35:29 PM(UTC)
Dryer starts, does not stop, no heat (Dryer Repair)
by Guest 6/28/2022 11:03:33 AM(UTC)
Samsung Electric Range-No Heat (Oven Repair (including Ranges and Cooktops))
by Jimh64 6/27/2022 8:39:17 AM(UTC)
Samsung Dryer DV448AEP/XAC - no heat (Dryer Repair)
by mgmjtech 5/18/2022 8:22:27 PM(UTC)
heeat turns on no heat comming up through floor register (Heating, Ventilation, and Air Conditioning (HVAC))
by Guest 2/6/2022 2:57:49 PM(UTC)
