maytag97l
#1 Posted : Saturday, September 29, 2007 11:12:47 AM(UTC)
maytag97l
Dryer makes a real bad squeaking noise from the back. It doesn't squeak in time with the drum. Sounds worse when you lean the dryer front or back. It is level. It has new glides, squeak is not consistant, loud :eek: then soft, stays loud, goes away???
richappy
#2 Posted : Sunday, September 30, 2007 1:41:28 AM(UTC)
richappy
Pull the back access plate and check the idler pulley, probably bad. If ok pull front panel and remove drum. Check the rollers in back and the blower wheel in front. You can check parts by clicking on your model # above.
Squeaky Dryer (Dryer Repair)
by luaumaster 8/21/2013 3:50:33 PM(UTC)
by jervisdj 7/2/2013 4:43:16 PM(UTC)
squeaky dryer (Dryer Repair)
by frankn 2/6/2012 7:35:57 PM(UTC)
by lgibson 9/9/2010 2:58:46 PM(UTC)
Repair of squeaky dryer (Dryer Repair)
by sbuckley@dtec.com 9/9/2010 11:36:44 AM(UTC)
very LOUD squeaky dryer (Dryer Repair)
by sdvia 8/26/2010 12:13:34 PM(UTC)
Squeaky dryer: which part(s) do I need (Dryer Repair)
by JerzyL 5/5/2010 7:35:02 AM(UTC)
Kenmore Squeaky Dryer (Dryer Repair)
by RussAwana 5/4/2010 8:00:57 PM(UTC)
Squeaky dryer (Dryer Repair)
by Bill in Mass. 11/13/2009 11:05:58 AM(UTC)
Loud Squeaky Dryer Noise (Dryer Repair)
by Hart1092 11/9/2009 2:54:19 PM(UTC)
by Alanna 9/18/2009 8:20:07 AM(UTC)
by SupermanRepairman 9/17/2009 5:31:27 PM(UTC)
by linus410 9/13/2009 7:54:27 AM(UTC)
by Kruldaddy 9/6/2009 9:00:42 AM(UTC)
by fiorillo 5/20/2009 6:21:27 PM(UTC)
