SupermanRepairman
#1 Posted : Thursday, September 17, 2009 5:31:27 PM(UTC)
SupermanRepairman
I've replaced the drum bearing system, as well as made sure nothing was touching the barrel as it turned. I put it back together and no change in the sound.
SublimeMasterJW
#2 Posted : Thursday, September 17, 2009 8:40:59 PM(UTC)
SublimeMasterJW
WE3X75 is the part number of the plastic rear drum support bearing. That is your squeak source.:D
SupermanRepairman
#3 Posted : Thursday, September 17, 2009 9:05:45 PM(UTC)
SupermanRepairman
I don't think that is it, The squeak only happens when a load is in the dryer. It's also louder when listening to it in the front opposed to the sides or behind it.
#4 Posted : Friday, September 18, 2009 2:17:55 AM(UTC)
As SublimeMasterJW said the rear bearing is the most common cause of squeaks in this unit which I believe you said has been replaced.
They can also be caused by the idler roller or motor bearings.
Could even be the front glides.
Often it is difficult to find the cause as sound can travel through the case/frame and be deceiving as to it's source.
I would try a drop of oil on the idler wheel and it's support rod where it attaches to the frame/motor. Use sewing machine or 3in1 oil not wd40 as wd40 in not a very good lubricant.
SupermanRepairman
#5 Posted : Friday, September 18, 2009 4:14:31 AM(UTC)
SupermanRepairman
The front glides seem likely. I did notice some areas that just looked worn on the front of the drum when I took it apart. I'll drop some oil or grease on it and see if it helps.
Squeaky Dryer (Dryer Repair)
by luaumaster 8/21/2013 3:50:33 PM(UTC)
by jervisdj 7/2/2013 4:43:16 PM(UTC)
squeaky dryer (Dryer Repair)
by frankn 2/6/2012 7:35:57 PM(UTC)
by lgibson 9/9/2010 2:58:46 PM(UTC)
Repair of squeaky dryer (Dryer Repair)
by sbuckley@dtec.com 9/9/2010 11:36:44 AM(UTC)
very LOUD squeaky dryer (Dryer Repair)
by sdvia 8/26/2010 12:13:34 PM(UTC)
Squeaky dryer: which part(s) do I need (Dryer Repair)
by JerzyL 5/5/2010 7:35:02 AM(UTC)
Kenmore Squeaky Dryer (Dryer Repair)
by RussAwana 5/4/2010 8:00:57 PM(UTC)
Squeaky dryer (Dryer Repair)
by Bill in Mass. 11/13/2009 11:05:58 AM(UTC)
Loud Squeaky Dryer Noise (Dryer Repair)
by Hart1092 11/9/2009 2:54:19 PM(UTC)
by Alanna 9/18/2009 8:20:07 AM(UTC)
by linus410 9/13/2009 7:54:27 AM(UTC)
by Kruldaddy 9/6/2009 9:00:42 AM(UTC)
by fiorillo 5/20/2009 6:21:27 PM(UTC)
by liang 4/21/2009 2:31:03 PM(UTC)
