I replaced my display of the oven about a month ago and I guess that wasn't the problem. My oven only works sporadically and it's only when the clock is showing or the error code E6 and F2 are displaying is when it will work. Then it will eventually beep and then shut off. I've tried to clean the ribbon with alcohol and that doesn't seem to work. Any suggestions? I really need my oven to work the holidays are coming fast. Thanks for your help!!
THIS FORUM IS DEAD!!!!!!! |
Now I'm getting error codes F5 and E1. Any ideas? Thanks for your help. Originally Posted by: denman ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif)
This is also related to the keypad. It still sounds like the control board is shat as the keypad is new. |
