mlindsey3418
#1 Posted : Tuesday, November 16, 2010 1:27:25 PM(UTC)
mlindsey3418
I replaced my display of the oven about a month ago and I guess that wasn't the problem. My oven only works sporadically and it's only when the clock is showing or the error code E6 and F2 are displaying is when it will work. Then it will eventually beep and then shut off. I've tried to clean the ribbon with alcohol and that doesn't seem to work. Any suggestions? I really need my oven to work the holidays are coming fast. Thanks for your help!!
#2 Posted : Wednesday, November 17, 2010 4:09:20 AM(UTC)
Replacement parts for WHIRLPOOL RBD275PDB14 27" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper | AppliancePartsPros.com
Since you have replaced the keypad and cleaned the connections I would say that the control board is shot.
There seems to be some confusion with the control board (Item 3 in Section 6), so it would be best to call and make sure you get the correct part.
As you have done a fair amount of troubleshooting you will probably be able to return the board if it does not fix your problem.
See AppliancePartsPros return policy.
This may also come in handy if you do not already have it.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/7d69e72584ddde3385256a7e00524e76/$FILE/8178007.pdf
mlindsey3418
#3 Posted : Saturday, November 20, 2010 6:49:26 AM(UTC)
mlindsey3418
Now I'm getting error codes F5 and E1. Any ideas? Thanks for your help.
Originally Posted by: denman Go to Quoted Post
https://secured.whirlpoo...524e76/$FILE/8178007.pdf
#4 Posted : Saturday, November 20, 2010 8:58:18 AM(UTC)
This is also related to the keypad.
It still sounds like the control board is shat as the keypad is new.
