M# ARGS 7650 WW P# 1130755 NWW
Okay, after searching forums here and chatting with the online help dude or whatever, I bought and replaced the ignitor. At least, I think that's what I did.
Symptoms: No heat in oven. Burners up top still all work, digital front panel seems to work, but when I press the oven button and choose a temp, it says 100 (this is where the temp starts on mine) then never goes up. I have tried the broiler and tried cleaning mode to see if it would start. I can make the temp go up by holding a match on what I believe to be the thermometer so that seems to work. Here is what I have done and possibly it can help someone else figure out what I still need to do.
1. shut off the gas to the stove and removed the gas line.
2. unplugged stove.
3. removed back panel (see pic, 4 screws)
![UserPostedImage](http://i96.photobucket.com/albums/l167/preregrin/oven%20repair/removingbackpanel.jpg)
4. removed the oven door. (2 screws) and the oven racks.
5. removed the old ignitor (I think that's what it was anyway, see pics 2 screws)
![UserPostedImage](http://i96.photobucket.com/albums/l167/preregrin/oven%20repair/ovenignitor.jpg)
6. traced the wires from the old ignitor out the back of the stove.
![UserPostedImage](http://i96.photobucket.com/albums/l167/preregrin/oven%20repair/ovenback.jpg)
7. undid the ceramic wire nuts and disconnected the old unit.
8. removed the protective metal cage from the old ignitor and placed it on the new ignitor then mounted the new ignitor inside the oven.
9. ran the new wires out the back.
![UserPostedImage](http://i96.photobucket.com/albums/l167/preregrin/oven%20repair/wirestoignitor.jpg)
10. wired the new wires to where I had removed the old ones, then replaced everything I had undone. (covers, doors, plugged in, turn gas back on etc.
start to finish it was 25 mins which is about what others here have stated.
Now, here's my dilemma: My oven still doesn't work. I replaced with part # AP 3440673 from this site which looked just like my old unit. I was careful not to touch the tip of the new unit as instructed. Everything went smooth, but it still doesn't heat up.
So to recap, oven no go, broiler no go, stove works. No glow to ignitor.
Is it possible to wire the ignitor backwards?? I assumed the two wires were reversible and just wired them up as before.
What else should I consider (besides buying a new oven)?
Thanks in advance. Sorry it's so wordy, but I thought if I used pics and words, I'd have a better chance of making myself clear, and possibly help someone else in the future.
