The fridge stops working and gets warm while the freezer stays nice and cold.
You will need to check your defrost system. With a GE it probably is the defrost heater, which is located behind the rear panel in the freezer part. There probably is a lot of frost & ice buildup on or behind that panel. Nat
I need some help taking off the back panel of the freezer to get to the defrost heater.Is there any other way to test the defrost heater?
Can you hear the fan running in the freezer?
