fay
#1 Posted : 16 years ago
fay
The fridge stops working and gets warm while the freezer stays nice and cold.
libertyappl
#2 Posted : 16 years ago
libertyappl
You will need to check your defrost system. With a GE it probably is the defrost heater, which is located behind the rear panel in the freezer part. There probably is a lot of frost & ice buildup on or behind that panel.
Nat
fay
#3 Posted : 16 years ago
fay
I need some help taking off the back panel of the freezer to get to the defrost heater.Is there any other way to test the defrost heater?
v2k04
#4 Posted : 16 years ago
v2k04
Can you hear the fan running in the freezer?
