mcdrell
#1 Posted : Wednesday, September 15, 2010 11:49:06 AM(UTC)
mcdrell
Hi,
We changed the lower bake element of the stove. Now it works for a while and then it turns of and gives the follwing fault code F-10 which does not exist. It seems as if the oven keeps heating and does not stop until the oven turns itself of and then gives me the f-10 code.
In addition, when we tested the self cleaning option it caused our breaker to jump.
The element we changed had whole burned threw it. When it self destructed, tt became realy red in one spot and did a loud poping sound.
What could be the problem? :confused:
Mcdrell
#2 Posted : Wednesday, September 15, 2010 2:51:48 PM(UTC)
Originally Posted by: mcdrell Go to Quoted Post
...When it self destructed, tt became realy red in one spot and did a loud poping sound...
Very likely it caused a damage to the control board. The correction is to replace the control board (aka a clock/timer).
- The control board Part number: AP3879797
wgcoop629
#3 Posted : Wednesday, September 15, 2010 6:24:16 PM(UTC)
wgcoop629
I had my bake element blow out on my 4 year old frigidaire. After replacing the element the oven would not heat. I replaced the control board (timer) and the oven works. I suspect the voltage surge when the element blows damages the control board. I don't know why you get an F10 error, but i suspect your board is damaged.
Befor you order the board, you may want to check your temperature probe. If it isn't working correctly your oven may be overheating and the safety thermostat shutting it off.
below is a link to a video for checking the temperature probe.
YouTube - Checking an Oven Temperature Sensor
Viking gas range oven troubleshooting (Oven Repair (including Ranges and Cooktops))
by MK_ 3/3/2024 10:10:13 AM(UTC)
Double Oven Trouble (Oven Repair (including Ranges and Cooktops))
by kctypes4u 9/19/2014 10:56:33 AM(UTC)
oven trouble (Oven Repair (including Ranges and Cooktops))
by steve79 6/15/2014 7:14:39 AM(UTC)
jenn air double oven trouble (Oven Repair (including Ranges and Cooktops))
by suelorio 12/2/2013 4:49:26 PM(UTC)
by ikey 12/16/2012 4:42:48 PM(UTC)
Caloric oven troubled (Oven Repair (including Ranges and Cooktops))
by vw66guy 12/9/2012 2:21:19 PM(UTC)
Jenn-air oven troubles (Oven Repair (including Ranges and Cooktops))
by SteveDB 10/8/2011 8:46:43 PM(UTC)
by childersjones 2/24/2011 2:58:58 PM(UTC)
electric oven troubleshooting (Oven Repair (including Ranges and Cooktops))
by prousseau 2/18/2011 6:27:10 AM(UTC)
amana oven trouble (Oven Repair (including Ranges and Cooktops))
by keithoak1 3/15/2010 5:22:58 AM(UTC)
by enzo731 5/29/2009 2:43:06 PM(UTC)
by nhoj 3/19/2009 2:29:03 PM(UTC)
whirlpool double oven trouble (Oven Repair (including Ranges and Cooktops))
by xmasvalley 1/24/2009 11:35:05 AM(UTC)
GE Oven Trouble (Oven Repair (including Ranges and Cooktops))
by at123 11/29/2008 10:18:40 AM(UTC)
