My GE Profile? Mod. JTP15W0D1WW started beeping (like the start button was being pressed), and finally displayed error code F0. I have reset the power (once over 24hrs), and reseated and cleaned the contacts on the ribbon cable. Now, after a power reset, the buttons will work on the key panel EXCEPT the 'start'. Do I need to replace only the ERC, or do I have to replace the key panel also, since 'start' doesn't seem to work now? Thanks!
I would replace the control panel first and there is a chance you would not have to replace the ERC. - The part number for the control panel is AP3186126 Here are the break down diagrams for the GE oven Model JTP15WD1WWGene.
