have dacor wall oven with faulty electronis. The light comes on and off by itself, then I couldn't set the clock although it displays, now in the middle of broil cycle it quit heating and won't heat on bake also but the convection fan comes on. Is this a faulty control panel or is there some kind of relay board that might cause this or something else?
Open the control panel and locate the thermal cut-off switch (next to the latch assembly). The thermal cut-off switch This switch is resettable. You can reset it by pushing in the red button in the middle. Check this switch for continuity after reset it. Replace the switch if it's still open. Also the control board most likely is bad and has to be replaced. Restore the power to the oven and check bake and broil. Post the results. - The part number for the thermal cut-off switch is AP3391739 - The part number for the control board is AP3390990 Gene.
i found this thread and it wa the reset switch on my model dacor 2200d oven. thanks so much for being here you saved me at least $200.00
