dryer works fine but no heat? Keeps blowing the T.C.O I have put 1 new one on and it blow in about 20 min. Thanking it is the P.C.M. Does this sound right to you? Thank you.
Originally Posted by: markcongdon ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) dryer works fine but no heat? Keeps blowing the T.C.O I have put 1 new one on and it blow in about 20 min. Thanking it is the P.C.M. Does this sound right to you? Thank you. At this time no, the PCB is the least likeliest problem. You need to check and make sure the exhaust pipe(in dryer), the lint filter,blower area, and the exhaust vent(in the wall),is not clogged or restricted with lint, check for kinked collapsed flex vent or crushed vent hood,etc . Then check for a shorted heater element or wire to the element. When you replace the TCO, you should also replace the hi limit thermostat(manufacturer reccomended procedure). Part number: AP4045617
Part number: AP4045367
You'll most likely find a vent or exhaust problem(in most cases) but you still need to repalce both thermostats.
Thanks Joe, I just replaced the vent with solid all new. The blue wire is unpluged from the tco and the pcb and i have contonuaty to ground and about 1.5vac with dryer pluged in none with unpluged. short in wire? P.S I do not spell very well I am very sorry. Thank You Originally Posted by: Joe / APP Team ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) At this time no, the PCB is the least likeliest problem. You need to check and make sure the exhaust pipe(in dryer), the lint filter,blower area, and the exhaust vent(in the wall),is not clogged or restricted with lint, check for kinked collapsed flex vent or crushed vent hood,etc . Then check for a shorted heater element or wire to the element. When you replace the TCO, you should also replace the hi limit thermostat(manufacturer reccomended procedure). Part number: AP4045617
No Short in heater element also it reads 12ohms Originally Posted by: Joe / APP Team ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) At this time no, the PCB is the least likeliest problem. You need to check and make sure the exhaust pipe(in dryer), the lint filter,blower area, and the exhaust vent(in the wall),is not clogged or restricted with lint, check for kinked collapsed flex vent or crushed vent hood,etc . Then check for a shorted heater element or wire to the element. When you replace the TCO, you should also replace the hi limit thermostat(manufacturer reccomended procedure). Part number: AP4045617
Originally Posted by: markcongdon ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) No Short in heater element also it reads 12ohms You did great, Your element is good. But, the blue wire is shorted somewhere in the harness or the cabinet frame. My guess is, it's somewhere near the heater or exhaust pipe, but that's only a guess. Shorted wires are the hardest thing to find in an appliance(unless the harness is burnt or has obvious damage). And remember, to replace both thermostats, when you repair the machine. Good Luck;)
Thanks Joe you have been a big help. Mark L Congdon Originally Posted by: Joe / APP Team ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) You did great,
Good Luck;)
Originally Posted by: markcongdon ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Thanks Joe you have been a big help. Mark L Congdon You're quite welcome, Let us know how things went.:cool:
Hey Joe can you tell me how much volts ac are at the T.C.O from the P.C.B Thank you. Originally Posted by: Joe / APP Team ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) You're quite welcome,
Originally Posted by: markcongdon ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Hey Joe can you tell me how much volts ac are at the T.C.O from the P.C.B Thank you. AC voltage from the PCB to the TCO is 120 volts on the blue wire, with the machine running in a heat mode. Did you find something else ? :confused:
No Just thought 120v might be high that is what i have thanks alot Joe you have been a big help. Mark L Congdon:) Originally Posted by: markcongdon ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Hey Joe can you tell me how much volts ac are at the T.C.O from the P.C.B Thank you.
