vbiondillo@norhill.net
#1 Posted : 15 years ago
My GE washer is overflowing when set to extra large. All other settings seem to be working properly. Any suggestions to troubleshoot this problem? Thanks in advance for your help. Let me know if you need any additional information.
richappy
#2 Posted : 15 years ago
richappy
Pull the small plastic hose off the water level switch and blow in it. If there was some soap residue in the tub, this will clear it. If that fixes the problem, add some vinegar in the tub to clear it out.
GE washer overflows after agitation unless extra small load WCXR1070TAWW (Washer Repair)
by Larry75243 11 years ago
GE Washer overflows (Washer Repair)
by doomee 15 years ago
ge washer overflows (Washer Repair)
by hilhp1 16 years ago
Ge Washer Overflows (Washer Repair)
by Starr77x 16 years ago
