doomee
#1 Posted : Tuesday, December 15, 2009 12:40:33 PM(UTC)
doomee
Help - i have a GE washer that is overflowing
I see several parts on-line that "probably" will fix the problem
i.e. water level switch, water inlet valve, and of course the timer
that controls everything??? please advise
#2 Posted : Tuesday, December 15, 2009 2:29:14 PM(UTC)
Open the control panel and make sure the pressure hose is properly connected to the water level switch (#10 on the diagram). Disconnect the pressure hose from the water level switch and blow some air into it to confirm the other end of the hose is connected to the tub and is clear.
If there is nothing wrong, replace the water level switch.
- The water level switch Part number: AP2045895
doomee
#3 Posted : Tuesday, December 15, 2009 2:57:05 PM(UTC)
doomee
With great respect you are certain the water level switch will fix the problem, of course i will change the tubing just in case it is cracked / leaking
GE washer overflows after agitation unless extra small load WCXR1070TAWW (Washer Repair)
by Larry75243 9/16/2013 11:10:36 AM(UTC)
GE Washer Overflows (Washer Repair)
by vbiondillo@norhill.net 8/3/2010 12:53:03 PM(UTC)
ge washer overflows (Washer Repair)
by hilhp1 10/21/2008 5:30:28 PM(UTC)
Ge Washer Overflows (Washer Repair)
by Starr77x 9/12/2008 3:23:38 PM(UTC)
