jeanpier
#1 Posted : Friday, July 25, 2008 11:22:47 AM(UTC)
jeanpier
I have Whirlpool Oven RBS305PDQ4 and the oven door will not stay closed during baking/broiling. What parts do I need to fix this? How do I access parts to replace them?
#2 Posted : Friday, July 25, 2008 8:55:03 PM(UTC)
This is very hard to diagnose problem due to many different parts involved. The best thing is to call a Whirlpool authorized technician.
jeanpier
#3 Posted : Saturday, July 26, 2008 1:36:06 PM(UTC)
jeanpier
Thank you, Gene. I assume that the hinges and springs are the problem. Are these difficult to replace? Where can I find a diagram?
If you think this is too tricky for average homeowner, please let me know and I will call repair person.
#4 Posted : Saturday, July 26, 2008 6:40:42 PM(UTC)
Replacing the door hinges could solve the problem and could not. If you would like to try, these parts are not too difficult to replace yourself.
Remove the door from the oven as described in the "Use and Care manual" (page 13). The part number for the door removal pins is AP3066060
Place the door on a flat surface with the door handle facing down and remove the screws holding the inner door panel. Remove the inner door panel.
- The part number for the door hinge assembly (both door hinges are identical) is AP3080711
Here are the break down diagrams for the Whirlpool oven Model RBS305PDQ4
jeanpier
#5 Posted : Monday, July 28, 2008 6:59:39 AM(UTC)
jeanpier
Gene,Thanks for much for your helpful reply--I will give this a try. Again, thank you for your generosity.
#6 Posted : Wednesday, July 30, 2008 4:37:24 PM(UTC)
You're welcome. Good luck.
jeanpier
#7 Posted : Thursday, July 31, 2008 11:44:37 AM(UTC)
jeanpier
Gene, I completed replacement of the hinges--it was quite easy with your guidance and it solved my problem. The oven door now closes securely.
For those who may wish to try this also, I probably did not need to order the pins as they came with the hinges but I certainly didn't need to order 2 sets. A small price to pay for an oven door that works!
Thanks again.
JP
Samsung - Oven Door Won't Close Tight (Oven Repair (including Ranges and Cooktops))
by Samich 4/26/2020 7:59:48 AM(UTC)
Oven door won't close tightly-has a gap (Oven Repair (including Ranges and Cooktops))
by gloverzoo 3/30/2015 7:45:00 PM(UTC)
Jenn-Aire Oven door won't Close (Oven Repair (including Ranges and Cooktops))
by jgmann 10/28/2014 11:58:22 AM(UTC)
GE Profile Oven Door won't close (Oven Repair (including Ranges and Cooktops))
by TeriT 8/27/2014 10:13:22 AM(UTC)
Thermador oven door won't close tightly (Oven Repair (including Ranges and Cooktops))
by fixitboy 11/26/2013 12:22:35 PM(UTC)
Kenmore Oven door won't close tightly (Oven Repair (including Ranges and Cooktops))
by ritarandall 9/24/2012 4:00:48 PM(UTC)
Oven door won't close (Oven Repair (including Ranges and Cooktops))
by DottieH 5/29/2012 1:15:24 PM(UTC)
Oven door won't close all the way... (Oven Repair (including Ranges and Cooktops))
by RN2010 11/21/2010 1:48:57 PM(UTC)
Oven door won't close right (Oven Repair (including Ranges and Cooktops))
by tsimonsen 5/28/2010 4:23:12 PM(UTC)
by mhamil1017 4/1/2010 10:07:51 AM(UTC)
Oven Door Won't Close!!! (Oven Repair (including Ranges and Cooktops))
by glenardee 9/28/2009 3:53:40 PM(UTC)
by hamconsulting 7/21/2008 8:37:21 PM(UTC)
Viking oven door won't close (Oven Repair (including Ranges and Cooktops))
by McDoo 12/3/2007 4:37:00 PM(UTC)
