jhuffar
#1 Posted : Tuesday, June 22, 2010 8:49:30 AM(UTC)
jhuffar
This is an update to my"dryer will not start" post yesterday. This is where I'm at now. I am looking at the start switch, PN 348314. it has three terminals on it marked as R1, R2, CT1. With dryer plugged in I have power at CT1. when I push the start button the coil pulls in and i have power at R1. The switch stays pulled in but the dryer will not start. If I open the door or turn dryet off by turning the timer wheel the switch will open and I can hear and see the coil release. So, should I have power at terminal R2. This is what makes me think it's the switch that is the problem. Any thoughts out there??
#2 Posted : Wednesday, June 23, 2010 5:06:45 AM(UTC)
I cannot find a wiring diagram for this unit so am doing some guesiing.
[COLOR="Blue"]it has three terminals on it marked as R1, R2, CT1.[/COLOR]
CT1 is one side of the coil other side is probably connected to R2
R2 is one side of the contacts usually connected to the motor.
R1v is the other side of the contacts usually connected to power (L1)
You could check this with a meter.
CT1 to R2 should read the relay coil resistance.
CT1 to R1 should be infinite ohms (open)
[COLOR="Blue"]With dryer plugged in I have power at CT1.[/COLOR]
In reference to where?
When referenced to Neutral I think you should have 0 volts here as normally it is connected through the door switch to Neutral.
[COLOR="Blue"]
when I push the start button the coil pulls in and i have power at R1. The switch stays pulled in but the dryer will not start. [/COLOR]
Again the following is just what is normal. There should always be power (when the timer is at a heating setting) at R1 when referenced to Neutral as it is connected through a set of timer contacts to L1.
[COLOR="Blue"]If I open the door or turn dryet off by turning the timer wheel the switch will open and I can hear and see the coil release. So, should I have power at terminal R2.[/COLOR]
Normally no but it depends where you are referencing it to.
When the relay pulls in you are closing the R1 to R2 contacts so there should be power at both. Since the relay does pull in and stays pulled in it is an indication that you do have power there.
It sounds to me that your relay is OK.
Following is a link to a different unit but it shows how many Whirlpools are wired but it is still a guess on my part.
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%203401723.pdf
I would unplug the unit, set it to mid cycle and check that timer switch 4 contacts are closed as they provide Neutral to the motor.
Be sure you disconnect one side to ensure that you do not read an alternate/parallel circuit path.
Also with door switch open you should read approximately 2 ohms from Relay R2 to W on the timer re: the 2 motor windings.
If infinite ohms I would say that the motor is toast.
I hope the above makes sense!!!
