meeksj
#1 Posted : Saturday, June 20, 2009 9:01:06 PM(UTC)
meeksj
I Checked And The Faucets Are On, Checked The Inlet Screens, Hoses Are Not Kinked, And Water Hoses Are Not Frozen. What Could Be The Problem?
#2 Posted : Sunday, June 21, 2009 3:35:29 AM(UTC)
Could find no info on the given Model Number.
Could it be that it is a GHW9150PW0
meeksj
#3 Posted : Sunday, June 21, 2009 10:15:17 AM(UTC)
meeksj
Thank You ,yes It Is Ghw9150pw0
meeksj
#4 Posted : Sunday, June 21, 2009 6:28:43 PM(UTC)
meeksj
YES IT IS GHW9150WP
#5 Posted : Monday, June 22, 2009 3:27:47 AM(UTC)
Replacement parts for WHIRLPOOL GHW9150PW0 | AppliancePartsPros.com
Here is a tech sheet
https://www.servicematters.com/d...0Sheet%20-%208182277.pdf
Here is a service manual for a 9100, I believe the 9150 is fairly close to this unit so hopefully it will help
https://secured.whirlpoo...ILE/Duet%20Job%20Aid.pdf
I am assuming that when you checked you water supply you ran the hoses into a pail to be sure they were OK. The reason is that hoses can collapse internally usually though you see a bulge on them, also many new homes have a hose burst system which can cause problems.
Try hot only and cold only to see if one of theses will work.
The tech sheet should help you narrow it down.
meeksj
#6 Posted : Monday, June 22, 2009 7:35:17 AM(UTC)
meeksj
Thank you so much, I will check the hoses better, and check out the teck sheet. THANK YOU AGAIN.:)
meeksj
#7 Posted : Tuesday, June 23, 2009 7:08:19 PM(UTC)
meeksj
It's not that my washer isn't geting enough water, its getting to much water then it beeps and flashes FH then it stops and drains all the water out. Is there a part that lets the washer know when to shut the water off. I even push pause button and then push the start button again and it dose the same thing over again.
#8 Posted : Wednesday, June 24, 2009 7:40:59 AM(UTC)
Sounds like either the water level switch or the flow meter
meeksj
#9 Posted : Wednesday, June 24, 2009 2:14:37 PM(UTC)
meeksj
THANK YOU SO MUCH.
frostywashdry
#10 Posted : Wednesday, June 24, 2009 3:14:18 PM(UTC)
frostywashdry
Agreed :):)
