pcroe
#1 Posted : 16 years ago
pcroe
I received your Repair Kit P/N 340032 for my Roper range, which is gas. Your shipping person tells me I received the correct part. However, the instruction sheet states that this for "Free Standing Electric Ranges." Is this the correct part for a gas range?
Also, the existing controller is a Robertshaw unit. The instructions for the replacement part give directions for rewiring the ground and for rewiring once of the leads to the three-pin connector. Do I need to make the rewiring changes for a gas range?
I look forward to your response.
Dan O.
#2 Posted : 16 years ago
Dan O.
That might be the part number of one of the components in a kit but not for the kit itself. What is the part number of the whole kit (probably on its box) that you received?
The same replacement control may be used in different applications. I don't know of any specific differences needed for use between a gas or electric range model.
If your installation has those components described, my guess would be yes, they likely need to be changed on your model as well. I have no personal experience with your installation though.
JMO
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
Range repair (Oven Repair (including Ranges and Cooktops))
by shalling 13 years ago
electric range repair (Oven Repair (including Ranges and Cooktops))
by Phillip88 14 years ago
Range Repair (Oven Repair (including Ranges and Cooktops))
by angels5491 14 years ago
Gas Range Repair Help (Oven Repair (including Ranges and Cooktops))
by l_harding 15 years ago
by wtravis 16 years ago
Hotpoint Range Repair (Oven Repair (including Ranges and Cooktops))
by jbox 16 years ago
by sheri vliet 16 years ago
by lamson471 18 years ago
