shalling
#1 Posted : Sunday, June 17, 2012 6:52:55 PM(UTC)
shalling
All burners on my electic stove do not heat. The red indicator light comes on but no heat. Have made sure all burners are connected right.
#2 Posted : Monday, June 18, 2012 2:24:46 AM(UTC)
Replacement parts for Frigidaire FDB751SCS0 Frigidaire/dishwasher | AppliancePartsPros.com
Does that include the stove top and oven elements?
If yes then odds are you have a power problem (no 240 volts).
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
electric range repair (Oven Repair (including Ranges and Cooktops))
by Phillip88 7/21/2011 4:44:12 AM(UTC)
Range Repair (Oven Repair (including Ranges and Cooktops))
by angels5491 5/31/2011 6:08:07 AM(UTC)
Gas Range Repair Help (Oven Repair (including Ranges and Cooktops))
by l_harding 3/25/2010 9:25:41 AM(UTC)
by wtravis 7/11/2009 11:00:03 AM(UTC)
Hotpoint Range Repair (Oven Repair (including Ranges and Cooktops))
by jbox 6/30/2009 11:59:24 AM(UTC)
by pcroe 6/12/2009 12:43:03 PM(UTC)
by sheri vliet 4/6/2009 7:22:45 AM(UTC)
by lamson471 8/2/2007 7:38:42 PM(UTC)
