This frig started make a grinding noise tonight ... sounds like a fan. It is not the condenser fan... I took a look and all is well. the noise is up top appeal loader when the doors are open... I need some ideas here as I have no idea what it could be???:confused:
David
So I turned off the breaker to the frig.... and when I turned it back on the noise was gone ... and is still gone. Maybe there was a piece if ice in the fan?
How would I know if I have a heater problem??:rolleyes:
Ok .. the evaperator fan noise is back... so the question is do I have a heater problem aof a fan problem ... or both.
Of course I do not wanr to order extra part ... but I have to get this done:eek:
It seem to be maybe a fan loose on the shaft or maybe a loose motor mount. When you gain access to it you might be able to see why it makes a noise at times. I don't think the heater would cause it.
Thanks ... I will take it apart asap
Well, I finally took the frig apart... and it was just ice builld-up over 10+ years.
Removed ice and lll is well!
