julimarie
#1 Posted : Saturday, December 22, 2007 11:12:51 AM(UTC)
julimarie
I noticed things melting in the freezer. The lights were on and the fan was running but I couldn't hear any other motors running. When I tried to pull it out from the wall it took some jerking to get it to move. When it was only a few inches out I hear a fan start running but making a loud clicking noise. I'm guessing it's the compressor fan.
Could this fan motor be the problem it's not cooling? If not, any ideas? Thank you.
misterfixall
#2 Posted : Saturday, December 22, 2007 4:56:46 PM(UTC)
misterfixall
you are referring to the condensor fan motor.it purpose is to draw heat away from the compressor. the compressor will overheat and shut down otherwise. check to see if th fan blade is hitting the shroud ,or a foreign object is preventing blade from turning .,possibly fan motor is failing .if so replace it .if nothing else is amiss it should return to normal, seasons greetings to you
julimarie
#3 Posted : Sunday, December 23, 2007 8:35:24 AM(UTC)
julimarie
Thank you! :) It seems the fan blades were bent out somehow and at least one was hitting the shroud. I bent them back and the noise stopped. The fan seems to be running fine. I'm now hoping the frig will cool again.
Thank you again. If it works Christmas will be saved! :D
Now I'm worried. I went to check if I could hear the compressor running but didn't. I listened closely but heard nothing then I heard a click, like it was trying to turn on, then a hum, then a click again and the hum stopped. I've always been able to hear the compressor when it's running so something tells me there's still something wrong.
richappy
#4 Posted : Tuesday, December 25, 2007 1:41:58 AM(UTC)
richappy
You probably have a bad start relay on the side of the compressor, just pull it out and see if it rattles, if so, order a new one. If overload and relay in one package, make sure you get the original factory part!!
Guest (5)
Refrigerator Fans & Compressor not running after reassembly. (Refrigerator & Freezer Repair)
by EC Haney 10/15/2021 2:59:18 PM(UTC)
Monogram ZISB420DRI compressor not running (Refrigerator & Freezer Repair)
by gunns 7/13/2019 8:38:55 AM(UTC)
GE Refrigerator Compressor not running. Help! (Refrigerator & Freezer Repair)
by JohnHoward28 4/4/2018 12:12:37 PM(UTC)
Compressor not running & very hot after moving it to another room (Refrigerator & Freezer Repair)
by scsu96grad 9/27/2015 11:10:33 PM(UTC)
GE Profile Refrigerator PFCS1PJXB SS / Compressor not running (Refrigerator & Freezer Repair)
by nj1971 6/9/2015 6:58:43 PM(UTC)
Compressor Not Running (Refrigerator & Freezer Repair)
by jkon2 6/3/2015 7:16:22 AM(UTC)
wont stay cool/compressor not running? (Refrigerator & Freezer Repair)
by chadf 6/9/2014 5:44:37 PM(UTC)
by repairmon 6/8/2014 6:45:17 PM(UTC)
Power Outage Fridge Fans and Compressor not Running (Refrigerator & Freezer Repair)
by ulric999 3/30/2014 7:56:00 PM(UTC)
GE compressor not running (Refrigerator & Freezer Repair)
by kwolfe 3/16/2014 6:34:38 AM(UTC)
by jeff143143 11/29/2013 1:50:19 PM(UTC)
Fan and Compressor Not running (Refrigerator & Freezer Repair)
by BLACKATTACK 9/7/2013 7:31:11 AM(UTC)
by herman 6/18/2013 2:27:04 PM(UTC)
by Dean F 12/2/2012 3:04:41 PM(UTC)
Refrigerator - Compressor not running (Refrigerator & Freezer Repair)
by GAJOHNSON51 7/17/2012 3:38:28 PM(UTC)
