jeff143143
#1 Posted : Friday, November 29, 2013 1:50:19 PM(UTC)
jeff143143
My refrigerator is not cooling (compressor not running).
Both condenser and evaporator fans running normal.
Coils clean and airflow not obstructed.
Checked overload protector 0 ohms resistance.
Checked Start Relay resistance seems to jump around I get anywhere from infinity to around 50 to 60 ohms.
Checked defrost timer manually turning this will turn off or on the evaporator fan, but will not turn on the compressor.
Checked compressor resistance between common and either start or run terminals and they both measure infinity. Between start and run terminals it measures 14.5 ohms
Seems there is a open winding in the compressor?
Just hoping I am missing something with the other tests
Any help or ideas
Jeff
PS Forgot to say I checked thermostat coldest setting resistance is zero, put in other freezer for minutes on warmest setting afterwards resistance is infinity.
#2 Posted : Saturday, November 30, 2013 12:06:16 AM(UTC)
See the attachment for the tech sheet. It shows compressor winding resistances.
[COLOR="Blue"]Checked compressor resistance between common and either start or run terminals and they both measure infinity. Between start and run terminals it measures 14.5 ohms[/COLOR]
Does sound like you have lost the common in the compressor.
I would re-check it just to be 100% sure of this.
If it is open then it will be an expensive repair as you need a new compressor and a pro. Usually it makes more sense to put the dollars towards a new unit.
Just to be 100% sure that you are measuring it correctly see the below link.
How To Fix a Refrigerator - Appliance Repair Guide - ACME HOW TO.com
The above is a long shot as your post looks to me that you know how to run a meter.
With luck there may still be some Black Friday deals around.
File Attachment(s):
RT18Dk.pdf (502kb) downloaded 7 time(s).
jeff143143
#3 Posted : Wednesday, December 4, 2013 7:36:21 PM(UTC)
jeff143143
Sorry I did not see your reply earlier. Have been busy. Double checked with another meter same results. Good tip for the ACME repair info. I seen the problem I was having with different readings on the Starter Relay.
Thanks for the info.
Refrigerator Fans & Compressor not running after reassembly. (Refrigerator & Freezer Repair)
by EC Haney 10/15/2021 2:59:18 PM(UTC)
Monogram ZISB420DRI compressor not running (Refrigerator & Freezer Repair)
by gunns 7/13/2019 8:38:55 AM(UTC)
GE Refrigerator Compressor not running. Help! (Refrigerator & Freezer Repair)
by JohnHoward28 4/4/2018 12:12:37 PM(UTC)
Compressor not running & very hot after moving it to another room (Refrigerator & Freezer Repair)
by scsu96grad 9/27/2015 11:10:33 PM(UTC)
GE Profile Refrigerator PFCS1PJXB SS / Compressor not running (Refrigerator & Freezer Repair)
by nj1971 6/9/2015 6:58:43 PM(UTC)
Compressor Not Running (Refrigerator & Freezer Repair)
by jkon2 6/3/2015 7:16:22 AM(UTC)
wont stay cool/compressor not running? (Refrigerator & Freezer Repair)
by chadf 6/9/2014 5:44:37 PM(UTC)
by repairmon 6/8/2014 6:45:17 PM(UTC)
Power Outage Fridge Fans and Compressor not Running (Refrigerator & Freezer Repair)
by ulric999 3/30/2014 7:56:00 PM(UTC)
GE compressor not running (Refrigerator & Freezer Repair)
by kwolfe 3/16/2014 6:34:38 AM(UTC)
Fan and Compressor Not running (Refrigerator & Freezer Repair)
by BLACKATTACK 9/7/2013 7:31:11 AM(UTC)
by herman 6/18/2013 2:27:04 PM(UTC)
by Dean F 12/2/2012 3:04:41 PM(UTC)
Refrigerator - Compressor not running (Refrigerator & Freezer Repair)
by GAJOHNSON51 7/17/2012 3:38:28 PM(UTC)
Drip pan full, fan on compressor not running? (Refrigerator & Freezer Repair)
by mpickell 6/23/2012 7:37:20 PM(UTC)
