Brandon1974
#1 Posted : Sunday, June 7, 2009 3:54:12 PM(UTC)
Brandon1974
I am working on an LG front load washer. When it starts the wash cycle it will rotate clockwise then it reverses , but the motor feezes up. It will rotate clockwise again, but eventually it gets hot and doesn't rotate either way. The tub spins freely when motor is not engaged. Any advice would be greatly appreciated. I have been working on mostly Whirlpool appliances for the past 15 years but this is the first LG. Thanks for any advice.
sidfink43
#2 Posted : Monday, June 8, 2009 12:13:46 PM(UTC)
sidfink43
Hi Brandon
Well, you are going to find out why anyone who works on washers pretty much hates LG.
About the best I can do for you is provide you a service manual. You should know these machines are famous for false error codes, bad wiring and in general the lack of friendly service from LG.
http://136.166.4.200/contents/L...M2075_Service_Manual.pdf
Good luck, let us know if this helps.
LG front load washer part id (Washer Repair)
by Cgreen0117 3/24/2024 10:49:09 AM(UTC)
LG front load washer water leak (Washer Repair)
by Guest 7/23/2022 11:17:44 AM(UTC)
LG front load washer making grinding noise (Refrigerator & Freezer Repair)
by Guest 9/18/2021 8:57:25 AM(UTC)
LG Front Load Washer rotor only turns if given a push. (Washer Repair)
by Emailtim 6/5/2020 1:49:05 PM(UTC)
LG Front Load Washer Barely Spins (Washer Repair)
by mckennwa 3/2/2017 6:30:55 AM(UTC)
lg front load washer (Washer Repair)
by melindai 4/15/2014 4:32:46 AM(UTC)
LG front load washer repair- special LG tool to remove the door front seal spring rin (Washer Repair)
by Paul Lukitsch 2/8/2014 10:07:25 PM(UTC)
LG front load washer (Washer Repair)
by reichegw 8/14/2013 10:10:34 AM(UTC)
LG front load washer no power (Washer Repair)
by waxmanak 6/10/2013 11:35:46 AM(UTC)
Leaking LG front load washer (Washer Repair)
by klinkster 6/6/2011 8:27:07 AM(UTC)
Lg Front Load Washer (Washer Repair)
by GIACOMO21 5/19/2011 5:21:43 AM(UTC)
LG front load washer (Dishwasher Repair)
by skimanforu 7/22/2010 3:48:02 PM(UTC)
