Jarinbixler
#1 Posted : Saturday, December 22, 2007 2:05:54 PM(UTC)
Jarinbixler
Washer has worked fine for 3 yrs. It now starts to fill, then water shuts off. It seems to be intermittent. What do you think?
misterfixall
#2 Posted : Saturday, December 22, 2007 8:05:34 PM(UTC)
misterfixall
does it happen on cold or warm or hot or all settings ,on every cycle , on what water level . is it just dead after water stops coming in. does it reach water level chosen. any humming sound.? have you tried advancing timer manualy to see what happens ? need more info
Jarinbixler
#3 Posted : Saturday, December 22, 2007 9:14:20 PM(UTC)
Jarinbixler
It seems to happen with any temp setting, every cycle, and every water level. Water begins filling like normal and then stops. I do hear a slight humming sound after it stops, sounds electrical. I have tried advancing the timer once it stops filling but nothing happens. I hope this info helps. I look forward to hearing from you soon...
misterfixall
#4 Posted : Sunday, December 23, 2007 4:01:07 AM(UTC)
misterfixall
buy what your tellin me it could be motor or some thing jammed in pump, like sock. motor+pump are conn ected sometimes it may be timer .you woul have to remove fron cabinet to acess pump +motor .remove pump clips ,pull off pump . turn machine on if water is still in tub ,see if motor runs in agitation cycle .if it does problem may be pump .you would have to remove pump hoses to look in ports its best to shop vac water ou of tub +clamp off drain hose from tub to pump, i usually jump connection to lid switch to effect spin .being this is intermitant problem may still be motor or timer even if you get motor to run .you can remove motor +try on its own
Kenmore Ultraclean Dishwasher wont fill (Dishwasher Repair)
by onlinefunner 5/4/2022 8:26:24 PM(UTC)
washer wont fill up or agitate .. but it fills up and spins (Washer Repair)
by machineguy 9/29/2015 6:13:36 AM(UTC)
by machineguy 9/28/2015 3:09:18 PM(UTC)
Washer Wont Fill (Washer Repair)
by PVJoel 3/23/2015 8:58:01 AM(UTC)
washer wont fill (Washer Repair)
by robnelson21 3/15/2015 9:52:14 PM(UTC)
ge profile washer wont fill (Washer Repair)
by Amgraywolf 9/15/2014 7:08:36 PM(UTC)
Maytag washer wont fill but spin cycle works (Washer Repair)
by kotis 8/18/2014 3:49:16 PM(UTC)
washer wont fill, no noise but will spin (Washer Repair)
by danniekendall@yahoo.coom 3/10/2014 5:46:38 PM(UTC)
whirlpool washer wont fill (Washer Repair)
by dennisthemenace 2/10/2014 8:35:36 AM(UTC)
by dennisthemenace 12/16/2013 7:45:20 PM(UTC)
Washer wont fill with water (Washer Repair)
by john1955 10/17/2013 5:20:51 AM(UTC)
Whirlpool washer wont fill (Washer Repair)
by whipskipper 9/8/2012 3:55:32 PM(UTC)
washer wont fill with water (Washer Repair)
by amtracker 6/16/2012 6:24:53 PM(UTC)
maytag dishwasher wont fill (Dishwasher Repair)
by willmcl 4/2/2012 11:44:10 AM(UTC)
Admiral washer wont fill (Washer Repair)
by jay1437 1/15/2012 1:35:43 PM(UTC)
