I washed 2 loads then went to do a third and the washer wouldn't fill on any cycle but spin cycle still works. I pull the selector knob and its like there is no power. No click no hum no water comes into the tub.
Open the control panel and check the fuse on the lid switch assembly. If blown, replace the lid switch assembly. It is designed to blow the fuse in the event that the lid switch fails in the closed position. Fuse is in the fill circuit and prevents washer from filling. Whirlpool 22001682 Lid Switch Assembly - AppliancePartsPros.comEric
