jsc2014
#1 Posted : Monday, July 10, 2017 6:45:42 PM(UTC)
jsc2014
I got this GE Fridge Freezer on bottom, it's not cooling hardly so I found the compressor fan wasn't working. I purchased a new fan and installed and it didn't work either.
Before discovering the compressor fan was not working I took the freezer panel off to check evaporator and it was fine. At that time I didn't unplug the fridge I just turn the temp setting to off and the defrost heater was on. Not sure if it was just the right timing or not. Is it possible for a fridge to be running and defrosting the same time causing the compressor fan not to run?
Model # GDS20SCSBSS
Guest
#2 Posted : Tuesday, October 3, 2023 8:08:00 AM(UTC)
Guest
Groups:
GE Profile fridge
Check your inverter ( compressor Electronic Unit)
Typically attached right next to the compressor and grey box… back of fridge
Part# wr49×10283 Depending on your fridge unit just a note, the part numbers may be different on the sticker attached to the unit,
Cost about $250 on Amazon , more at a dealer. It’s not hard to replace, few screws, and a few quick connect harnesses.
If your compressor and fan are not working, this is most likely the issue as to why your fridge and freezer are not cooling off.
Edited by user Tuesday, October 3, 2023 8:27:16 AM(UTC)  | Reason: Missing information.
GE Fridge GFE28GMKJES Ice Maker Not Working (Refrigerator & Freezer Repair)
by aopenshaw 2/9/2024 8:35:22 AM(UTC)
GE fridge water dispenser slows to trickle, speeds up when filter is twisted (Refrigerator & Freezer Repair)
by Guest 1/11/2024 5:03:35 AM(UTC)
GE fridge, Evaporator Heater fried (Refrigerator & Freezer Repair)
by Guest 9/23/2023 8:19:17 AM(UTC)
Freezer is not cooling, fan is not working, light not on, NEW control board; GE fridge GSS25GSHJCSS (Refrigerator & Freezer Repair)
by Guest 8/6/2023 3:06:23 PM(UTC)
Freezer fan doesn't work, new control board; GE fridge GSS25GSHJCSS (Refrigerator & Freezer Repair)
by Guest 8/6/2023 3:02:45 PM(UTC)
GE Fridge - no ice (Refrigerator & Freezer Repair)
by Guest 1/22/2023 8:39:51 AM(UTC)
Replacement freezer gasket for GE Fridge GSS25JFMAWW (Refrigerator & Freezer Repair)
by Guest 11/13/2022 8:12:45 AM(UTC)
Monogram GE fridge (Refrigerator & Freezer Repair)
by Guest 8/23/2021 5:24:17 AM(UTC)
GE fridge front control panel is off (Refrigerator & Freezer Repair)
by frank1979 4/5/2021 10:10:58 PM(UTC)
gsl22jftabs ge fridge nit runnubg after power outage yesterday (Refrigerator & Freezer Repair)
by Guest 3/25/2021 7:14:05 AM(UTC)
GE Fridge model CFSP5RKBBSS - No Icecubes (Refrigerator & Freezer Repair)
by HaroldS 2/13/2021 2:17:30 PM(UTC)
33 year old GE fridge not cooling (Refrigerator & Freezer Repair)
by stevebass 7/11/2020 4:05:50 PM(UTC)
GE fridge - frost in ice cube dispenser (Refrigerator & Freezer Repair)
by rchrdm 4/13/2020 4:06:53 PM(UTC)
GE fridge has 20kHz audible noise (Refrigerator & Freezer Repair)
by mprmeyer 4/9/2020 7:47:39 AM(UTC)
Do NOT buy WR24X10302 or WR24X10296 for GE fridge. (Refrigerator & Freezer Repair)
by apmin 2/21/2020 7:35:36 AM(UTC)
