Q:(Why does my lg washing machine slow down the tub then stop the spinning?) A:because the LED say "1;or3" after a few or 15 minutes of spinning the lg washing machine tub,because it causes so much of spinning tub on the go for lg wash. S:1. Check your tub as it say "3" by pressing the start /pause button and power button to turn off. 2.Check your tub as it UE the LED up the tub. If not,close the door. 3.Drain and spin again. E:Thank you for the issue!!! F:Thank you!!! Q=Question A=Because answer(s) S=Skills to think E=Before Finshed(End) F=Finshed
Thanks for the info!!! Thanks!!!
Do spin come after rinse? Rinsing. Rinse the whole tub before all the water has been rinsed. Spinning. Spin the tub really fast to remove acess water,slows down then stop the tub to acess last drain after spin 1 minute before the washer has been finshed. What makes our 2018 LG washer tub spinning then slow down after it spun...
What's "Drain+Spin"? Every time you have drained your tub already,it will spin after,to remove acess water into a really fast tub rotation to remove a few clothes in the tub before it finshed. Only the 2018 LG tub has been brought...
To turn off or on lg sound,press the signal button by holding the custom PGM button.
The lg washing machine will chime when the LED say End,because the ending song shows that the massage said that the chime sings the afterwash conduction that chimes every time the washer's been finshed. 2018,I knew that chimes every time the washer has been ended...
And now we are done. Edited by user Monday, July 4, 2022 10:32:15 AM(UTC)
| Reason: Not specified
Why does my macbook air make noise when i restart it? The Mac has a 3-second startup sound that chimes every time you boot up your Mac. But if you're a Mac user,you hear the chime since or when you reboot or restart your Mac in any time.
Why does my macbook air keep dinging while charging? Because the charger outlet has been charged but not charging properly like a LE lg error. You should be able to charge properly before using it,or after a few weeks the battery might be dead. Or your Mac can throw up when the battery is dead while sleeping for a few weeks of life. So that is life!!! Enjoy!!!
