deanowhitney
#1 Posted : Wednesday, July 11, 2018 11:22:38 AM(UTC)
deanowhitney
set temp to bake 350\\ top element heats (185) no heat on bottom element
110volts to each leg of bottom element
Full continuity on bottom when pwr off- no resistance
Set upper element leads to bottom element-pwr on - red hot 220volts across terminals
Pwr from L1 -> upper element and lower element (OK)
Pwr from L2 -> control switch of bake element and AUX (OK)
control switch E7 sends current to Upper element E6 sends current to lower element
With oven turned on to bake, I get a reading across Upper element terminals of 220v and the lower element nothing across the two terminals, but 110v from each to ground.
Yellow wire from switch E6 to Lower element
Purple wire from switch E7 to Upper element
Can't figure why the bottom element only gets 110V on each terminal when should be 220V
CarolynE
#2 Posted : Wednesday, July 25, 2018 8:49:01 AM(UTC)
CarolynE
thermosensor?
Gas Oven not heating up (Oven Repair (including Ranges and Cooktops))
by Guest 2/8/2024 7:09:48 PM(UTC)
Thermadore PRG304GH oven not heating (Oven Repair (including Ranges and Cooktops))
by Guest 12/15/2022 6:58:50 AM(UTC)
upper oven not heating up to desired temp. it's off by about 50 degrees (Oven Repair (including Ranges and Cooktops))
by Guest 10/14/2022 12:50:23 PM(UTC)
Bottom oven not heating (Oven Repair (including Ranges and Cooktops))
by Castelle 1/21/2022 6:17:26 PM(UTC)
Monogram electric oven not heating (Oven Repair (including Ranges and Cooktops))
by Norploc 2/26/2021 12:56:03 PM(UTC)
Frigidaire GLEF378CBD - oven not heating (Oven Repair (including Ranges and Cooktops))
by canooten 3/20/2020 11:24:19 AM(UTC)
GE gas oven not heating (Oven Repair (including Ranges and Cooktops))
by 1alembic 4/4/2018 5:59:05 PM(UTC)
Oven not heating when using convection (Oven Repair (including Ranges and Cooktops))
by ebonyclose 3/11/2018 7:37:25 PM(UTC)
Frigidaire Double Oven - Lower Oven not heating - Clicking (Oven Repair (including Ranges and Cooktops))
by RentAHubby 10/3/2017 8:42:44 PM(UTC)
Whirlpool Oven not heating (Oven Repair (including Ranges and Cooktops))
by proto8432 7/15/2017 10:07:03 AM(UTC)
Oven not heating up and gas smell in house (Oven Repair (including Ranges and Cooktops))
by DJKNY71 1/18/2017 7:06:47 AM(UTC)
Upper oven not heating, lower over works properly (Oven Repair (including Ranges and Cooktops))
by Greg2cycle 11/5/2016 9:50:34 AM(UTC)
Oven not heating properly (Oven Repair (including Ranges and Cooktops))
by Rentalmom5 9/14/2016 6:24:38 AM(UTC)
Whirpool Oven not heating (Oven Repair (including Ranges and Cooktops))
by cdfrerichs01 8/7/2016 10:55:06 AM(UTC)
New wall oven not heating (Oven Repair (including Ranges and Cooktops))
by stagestruck 2/11/2016 11:38:47 AM(UTC)
