johna56
#1 Posted : Tuesday, December 26, 2017 11:32:44 AM(UTC)
johna56
My Whirlpool gas water heater was installed 2-3 years ago and is not maintaining the temperature of the water. The water is often room temperature or cooler. The temperature knob has been dialed to its highest temperature. When the pilot is turned off, and re-lit 30 minutes or so later, the water will remain relatively hot for the next hour or two.
According to the manufacturer, due to the existing (improper for this unit) side venting, the wind is pushing back into the unit and that is affecting the tanks ability to heat, or keep the water heated.
I'd like to get another two-three years out of my current tank. Does anyone have any insight or suggestions as to what part could be replaced to get this part working again and if its replaceable? I'd like to get another 2-3 out of my current tank before I have convert to tank-less.
Thank you.
seattlepioneer
#2 Posted : Monday, January 22, 2018 12:15:58 PM(UTC)
seattlepioneer
The thermostat is bad and needs to be replaced.
gas hot water heater flame sensor (General Talk)
by normpete 1/21/2022 9:10:29 AM(UTC)
Electric Hot Water Heater (Forum Announcements)
by paul gesche 9/7/2019 9:39:25 AM(UTC)
Ever decreasing hot water throughout house- Hot Water Heater (Heating, Ventilation, and Air Conditioning (HVAC))
by Boiler20 6/30/2014 7:25:33 PM(UTC)
Hot water heater anticipator (Heating, Ventilation, and Air Conditioning (HVAC))
by jbili 11/30/2011 3:46:02 PM(UTC)
Replacing gas hot water heater only for higher efficiency.... (Heating, Ventilation, and Air Conditioning (HVAC))
by Olives 7/21/2010 4:15:57 AM(UTC)
Hot Water heater (Heating, Ventilation, and Air Conditioning (HVAC))
by Rick1 1/24/2010 1:34:07 PM(UTC)
Gas Hot Water Heater Broken? (Heating, Ventilation, and Air Conditioning (HVAC))
by bmyu 12/26/2009 6:12:22 AM(UTC)
40 Gal. Dual Element Electric Hot Water Heater (Heating, Ventilation, and Air Conditioning (HVAC))
by Teager 9/11/2009 1:21:26 PM(UTC)
hot water heater (General Talk)
by conjp57 10/17/2008 8:47:09 PM(UTC)
bosch tankless hot water heater (Heating, Ventilation, and Air Conditioning (HVAC))
by artie in miami 8/17/2008 1:12:00 PM(UTC)
hot water heater (Forum Announcements)
by angidale 8/12/2008 4:40:04 PM(UTC)
Hot Water Heater won't stay lit. (General Talk)
by bulll 5/20/2008 8:51:10 AM(UTC)
wiring hot water heater (Heating, Ventilation, and Air Conditioning (HVAC))
by kyle pennsylvania 12/29/2007 2:23:19 PM(UTC)
