I will appreciate all your help,
I have a whirlpool washer, when I turn on the washer, it start with the first cycle that is fill, the status led is on, then when the washer reach the water level, the led status of fill is on and also the lid lock led status is on, then the it does not advance to the next cycle.
what could be the problem if the lid lock is working properly. :(
regards.
Joined: 6/13/2014(UTC) Posts: 781 Was thanked: 1 time(s) in 1 post(s)
There are a number of issues that can cause your problem. I would suggest contacting the store where you purchased the machine to see if it is still covered under warranty.
