invader37
#1 Posted : Friday, June 16, 2017 7:56:36 AM(UTC)
invader37
No hot or cold water. Changed temperature switch. No help. Changed water inlet and sensor just in case and no help. Get 120v at cold valve with switch set at "Cold", but only getting 2v at Hot valve when switch set at"Hot'. Checked resistance on Inlet assemblies and they are the same on both new and old. Is new switch bad the only option left?
invader37
#2 Posted : Friday, June 16, 2017 8:00:40 AM(UTC)
invader37
Question should read no Hot or warm water.
invader37
#3 Posted : Friday, June 16, 2017 8:01:31 AM(UTC)
invader37
No hot or warm water. Changed temperature switch. No help. Changed water inlet and sensor just in case and no help. Get 120v at cold valve with switch set at "Cold", but only getting 2v at Hot valve when switch set at"Hot'. Checked resistance on Inlet assemblies and they are the same on both new and old. Is new switch bad the only option left?
brobriffin
#4 Posted : Friday, June 16, 2017 11:59:33 AM(UTC)
brobriffin
Man
First rule out bad hot valve.
change the wires from the cold valve to the hot valve. run a cold cycle and see if hot valve opens.
invader37
#5 Posted : Friday, June 16, 2017 1:35:15 PM(UTC)
invader37
I had actually switched the hot and cold inputs before installing the new switch. Not having a wiring diagram. I changed the valve assembly thinking maybe the sensor might be able to shut off the hot if the sensor was bad,
brobriffin
#6 Posted : Friday, June 16, 2017 4:34:47 PM(UTC)
brobriffin
Man
this model does not appear to have an actual temp sensor
it is controlled by the water temp switch
ok so when you had the wiring backwards did the hot water work?
invader37
#7 Posted : Friday, June 16, 2017 5:34:43 PM(UTC)
invader37
Yes, I had hot water with the cold line connected to hot valve input
brobriffin
#8 Posted : Saturday, June 17, 2017 8:18:30 AM(UTC)
brobriffin
Man
Ok so the valve is not the issue.
Like you said you were only getting 2 volts to the hot water side.
Therefore your water temp switch is likely the culprit here.
Now for the bad news, whirlpool has discontinued this part.
It may be available with a search thru the web or other secondary aftermarkets.
The part number you will nee to look for is 8571735
Guest (9)
No hot or warm water in washer/dryer combo (Washer Repair)
by Shelbel 3/12/2013 11:22:15 AM(UTC)
Maytag Atlantis Washer No Hot Or Warm Water (Washer Repair)
by jakemdr 3/4/2010 7:46:38 PM(UTC)
