AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Samsung VRT Vibrating/Knocking at spin (high RPM)
Joined: 6/13/2014(UTC) Posts: 781 ![Man Man](/Themes/yafvision/male.gif) ![United States United States](/Content/images/flags/US.png) Was thanked: 1 time(s) in 1 post(s)
Your outer bearing looks to be in great shape BTW.....
Question...I can't believe I unloosened this clapand lost the nut. I couldn't find this under the clamps and I cannot find locally....yet. Other clamps will not holt the tube in place. This comes from the tub to a drain hose Pic attached Thank you Kovachbt attached the following image(s):
Would a screw type clamp work like you could get at auto parts store?
If your hunting clamps I must imagine you've removed and fixed the support arm?
Yep.... the tub to pump hose is the only thing that remains.
I've tried zip ties regular screw clamp but nothing holds the hose. It keeps slipping off
Was hoping it could get through the site. Going to look at some local repair center tomorrow
Anxious to see if the washer is fixed.... let alone do laundry
Thanks for all your help
Wish I was writing with good news
Washer is together and taking it for a test run on spin cycle.
Tub fills up and it seems to want to spin but doesn't... tub rocks minimally and seems stuck in the cycle
Not sure what to do expect go back thru and verify all the connections
Could I not have the magnet and stator on completely?
Ok.... went back and shook the tub / manually spun it. Ran the rise cycle and it actually spun for a few rotations and froze back up.
Check all wiring connections. Remove rotor and check for proper stator placement. Check wiring to stator, it has a rotor position sensor. Replace rotor making sure it is completely seated over stator. recheck a rinse and spin cycle
Good morning Sending you this attachment.... is this normal that the shaft is not flush with the housing? Could this be my issue? Thank you Kovachbt attached the following image(s):
Washer Repair
