4 Pages<1234>
brobriffin
#11 Posted : Friday, June 9, 2017 7:40:29 AM(UTC)
brobriffin
Man
Your outer bearing looks to be in great shape BTW.....
Kovachbt
#12 Posted : Sunday, June 11, 2017 12:28:17 PM(UTC)
Kovachbt
Question...I can't believe I unloosened this clapand lost the nut.
I couldn't find this under the clamps and I cannot find locally....yet. Other clamps will not holt the tube in place. This comes from the tub to a drain hose
Pic attached
Thank you
Kovachbt attached the following image(s):
brobriffin
#13 Posted : Sunday, June 11, 2017 3:30:18 PM(UTC)
brobriffin
Man
Would a screw type clamp work like you could get at auto parts store?
brobriffin
#14 Posted : Sunday, June 11, 2017 3:37:33 PM(UTC)
brobriffin
Man
If your hunting clamps I must imagine you've removed and fixed the support arm?
Kovachbt
#15 Posted : Sunday, June 11, 2017 4:01:54 PM(UTC)
Kovachbt
Yep.... the tub to pump hose is the only thing that remains.
I've tried zip ties regular screw clamp but nothing holds the hose. It keeps slipping off
Was hoping it could get through the site. Going to look at some local repair center tomorrow
Anxious to see if the washer is fixed.... let alone do laundry
Thanks for all your help
brobriffin
#16 Posted : Sunday, June 11, 2017 5:08:34 PM(UTC)
brobriffin
Man
http://www.appliancepartspros.c...65-00014a-ap4206370.html
this is the part # of the clamp you seek
Kovachbt
#17 Posted : Wednesday, June 14, 2017 1:14:28 PM(UTC)
Kovachbt
Wish I was writing with good news
Washer is together and taking it for a test run on spin cycle.
Tub fills up and it seems to want to spin but doesn't... tub rocks minimally and seems stuck in the cycle
Not sure what to do expect go back thru and verify all the connections
Could I not have the magnet and stator on completely?
Kovachbt
#18 Posted : Wednesday, June 14, 2017 1:23:55 PM(UTC)
Kovachbt
Ok.... went back and shook the tub / manually spun it. Ran the rise cycle and it actually spun for a few rotations and froze back up.
brobriffin
#19 Posted : Wednesday, June 14, 2017 2:28:09 PM(UTC)
brobriffin
Man
Check all wiring connections.
Remove rotor and check for proper stator placement.
Check wiring to stator, it has a rotor position sensor.
Replace rotor making sure it is completely seated over stator.
recheck a rinse and spin cycle
Kovachbt
#20 Posted : Thursday, June 15, 2017 4:09:39 AM(UTC)
Kovachbt
Good morning
Sending you this attachment.... is this normal that the shaft is not flush with the housing? Could this be my issue?
Thank you
Guest (10)
4 Pages<1234>
