wildblue
#1 Posted : Sunday, March 5, 2017 3:31:47 PM(UTC)
wildblue
My Whirpool Special Edition washing machine with 2 speed motor and 2 load choices, Small and Extra Large, fills at extremely slow rate for hot water but normal rate for cold water. I would assume the hot water control valve is stuck in an almost closed position. Any help would be appreciated otherwise I'll have to disconnect the hot hose and add a ball valve to hose and then manually fill the tub with hot water.:mad:
brobriffin
#2 Posted : Monday, March 6, 2017 3:57:35 PM(UTC)
brobriffin
Man
Can you give the model number?
It should be on a label under the lid on the rim.
wildblue
#3 Posted : Tuesday, March 7, 2017 12:15:53 PM(UTC)
wildblue
From memory Model Number is LXR or LSR 6232EQO.
ThatGuy
#4 Posted : Tuesday, March 7, 2017 12:32:09 PM(UTC)
ThatGuy
Originally Posted by: wildblue Go to Quoted Post
Model Number is LXR6232EQO
Here's your part. At $12 I'd just replace it and be done.
Whirlpool 285805 Water Inlet Valve - AppliancePartsPros.com
jimctec
#5 Posted : Wednesday, March 8, 2017 3:11:49 PM(UTC)
jimctec
Take the hot water hose off at both ends. Look for a screen in the top end of the hose & clean, and also clean the screen inside the hose connection on the machine. Attach the hose at the top and point it into the tub or down the drain and check flow rate, then connect to machine and try hot fill...
ThatGuy
#6 Posted : Wednesday, March 8, 2017 3:21:04 PM(UTC)
ThatGuy
Or spend $12 and be done with it. What is your time worth?
brobriffin
#7 Posted : Wednesday, March 8, 2017 3:52:57 PM(UTC)
brobriffin
Man
Lets see....
Clogged screen - or bad valve
down for three plus days so far... laundry stacking up
check for clogged screen
order a valve (that can be returned within 365 days)
find problem
fix problem
make wife happy
PRICELESS!
