F20 Code - researched at APP and YouTube, I ordered the Water Inlet Flowmeter, thinking it was the problem. Replaced it with new one from APP. Ran 2 loads and F20 back. In the wash cycle it goes through soap tray, but not bleach tray. By the third water cycle the barrel fills up half way, F20 comes on, just as it did before. My wife presses the pause/cancel, then switches to rinse/spin to finish load out. I don't like to keep on changing parts out when it's not needed as YouTube guys did. What could be the problem? It appears the Water Level Switch works in the rinse/spin cycle. But the wash cycle going through the soap and not switching to the bleach and filling up the barrel half way?????? I have read in the APP about the dispenser assemble could be plugged and it appears there has been some boil out of powdered soap up through the top holes of the dispenser. I will check that today for plugged ways the water travels. Thanks, look forward to the help.
This is Kbcbrown2017, as far as I can see no one has replied to this problem? Am I doing something wrong as far as POSTING? KB
Joined: 7/27/2010(UTC) Posts: 1,395  Location: near the middle of nowhere Was thanked: 24 time(s) in 24 post(s)
If I knew anything about it, I'd help, but I really don't. Sorry.
