2 Pages<12
Joe / APP Team
#11 Posted : Monday, February 22, 2016 5:41:49 AM(UTC)
Joe / APP Team
Originally Posted by: Tdouble14 Go to Quoted Post
I'm having a problem with my ghw9100lw where the timer changes when selecting different cycles, buttons all work but won't start. I tried billions of times to due the diagnostics test but the time just flickers when pressing the rinse hold button for the fourth time. On top of that when I'm in this cycle setting ready for diagnostics if I press start I hear a click in the back and the number flashes. I'm truly at a lost because I can't find anything online dealing with the machine showing no error codes or not going into diagnostic mode.
Tdouble, Remove the top panel, and unplug the power cord from the outlet, locate the CCU, it's attached to the side or back wall of the cabinet. Listen closely, when you plug the cord back into the outlet, you should hear a click from the line relay on the control board. If the click occurs, use the attached tech sheet to access and check the user interface and control panel keys, and the harness between the UIC and The CCU. Review the troubleshooting information at the end of the manual, it'll help you to find a place to start the diagnosis process.
File Attachment(s):
Tech+Sheet+-+8181790+-+Rev+A.pdf (147kb) downloaded 19 time(s).
scottthefixitguy
#12 Posted : Saturday, December 17, 2016 10:22:42 PM(UTC)
scottthefixitguy
If your duet washer won't start its most likely due to a bad part behind the start button.
Here's how to fix it at home for 35 cents: https://youtu.be/N8rz8sclwAg
scottthefixitguy
#13 Posted : Saturday, December 17, 2016 10:23:40 PM(UTC)
scottthefixitguy
Joe / APP Team
#14 Posted : Monday, December 19, 2016 8:21:18 AM(UTC)
Joe / APP Team
Scott, Thanks for the update and the You Tube Repair Video. We appreciate it.
ThatGuy
#15 Posted : Monday, December 19, 2016 8:56:29 AM(UTC)
ThatGuy
Are you in charge here?
Just in case you didn't notice, Scott is a SPAMBOT. "he" posted that same post in 7 other places on this forum and twice in this thread.
The youtube address he links to is youtu.be. Yeah, that just ain't right!
Notice the link below. youtube. Its a real one, his is not.
https://www.youtube.com/watch?v=Q3eYF53Pj8g
Joe / APP Team
#16 Posted : Monday, December 19, 2016 9:24:47 AM(UTC)
Joe / APP Team
That Guy, No I'm not in charge, I've been here a while, bit I don't post or reply to the repair forum as often as I used to.
I don't know of Scotthefixitguy, and yes he has posted the you tube video several times, but it was a quick simple temporary repair and easy for most DIY'rs to view and repair the machine. I'm sure there are other methods and components to use for a more permanent repair, but thought it would be helpful, down the line. Thanks for the update and heads up.
scottthefixitguy
#17 Posted : Monday, January 2, 2017 10:02:54 PM(UTC)
scottthefixitguy
Here is a video on how to repair the broken start button using duct tape.
It saves you about $300.00 on a new interface control board.
Hope this helps: https://youtu.be/N8rz8sclwAg
Good Luck,
Scott
Brt123
#18 Posted : Wednesday, December 6, 2017 4:42:30 PM(UTC)
Brt123
Happy mom how did you get your machine working? I'm ready to blow this one up!!! It's doing as you posted. Thx Brandon
Joe / APP Team
#19 Posted : Thursday, December 7, 2017 5:23:42 AM(UTC)
Joe / APP Team
BRT123, Happy Mom didn't post a response or an update. But , Like her and most of the people on this thread, you most likely have a problem with the user interface tabs, so you'll need to remove power and access the user interface and check for broken buttons and tabs. All the information you need is posted through out the thread(including the service manual) Once you're there and determine the problem isn't the User Interface, drop us a line, and let us know what you did find, and we'll carry on from there. Thanks,
Guest
#20 Posted : Monday, May 16, 2022 3:32:13 PM(UTC)
Guest
I have a whirlpool duet wfw94heawo
I tried to get into diagnosis mode by turning the control knob and I get nothing the leds switch positions like I am switching load types but will not go into diagnosis mode. I get an e01 error and see that the mcu or ccu boards could be the issue. Anyone have any idea how to diagnosis the error and how I need to move forward with this
Guest (6)
2 Pages<12
