Hoglie
#1 Posted : Monday, June 27, 2016 9:38:07 AM(UTC)
Hoglie
We have a Whirlpool washer that bounces all over the place while spinning out ant it is getting worse. It has been leveled so that should't be the problem any help would be greatly appreciated.:confused:
brobriffin
#2 Posted : Tuesday, June 28, 2016 6:16:14 AM(UTC)
brobriffin
Man
Hoglie,
Try the bounce test! While the tub is empty open the lid push down on each of the corners of the tub. Let go rapidly if the tub bounces up and down several times on any of the corners, then the suspension rod/springs are bad. Those supports should only bounce back up and stop. If they bounce, you can purchase replacement springs right here @
Whirlpool W10780040 Suspension - AppliancePartsPros.com
I recommend to replace all 4 at the same time or else you will be chasing uneven loads until you do!
Hoglie
#3 Posted : Tuesday, June 28, 2016 8:01:12 AM(UTC)
Hoglie
When you push down on any corner it pops back up and then wobbles for a few seconds,so I'm guessing it needs the rods, now here's a question how do I access them just to double check and replace them on this model? Thanks in advance.
brobriffin
#4 Posted : Tuesday, June 28, 2016 9:36:01 AM(UTC)
brobriffin
Man
On your model you must unscrew the two retaining screws at the back side of the lid at the hinges, as well as remove the wire harness cover at the back right side of machine to lift the lid. Then slide the lid forward lift about 1/4 inch then slide backward to lift completely open.
Hoglie
#5 Posted : Thursday, August 4, 2016 9:18:46 AM(UTC)
Hoglie
I got and installed new stabilizer rods and re-leveled the washer but it still bounces although not as bad but still doing it. What else can be done?
brobriffin
#6 Posted : Thursday, August 4, 2016 11:42:18 AM(UTC)
brobriffin
Man
I would imagine there is some bounce during the initial stage of the spin cycle which is common for it to wobble just a bit. The machine itself shouldn't bounce up and down however.
Something to keep in mind is to wash balanced loads. In other words don't wash say a large bath towel and several t-shirts. Wash only "like items" to prevent unbalance (all towels or all light weight clothes).
Out of Balance Samsung WF520ABP/XAA (Washer Repair)
by johnb0529 6/24/2021 10:25:37 AM(UTC)
Roper washer RTW4640YQ1 out of balance (Washer Repair)
by seagypsy 10/3/2020 5:00:03 PM(UTC)
Samsung washer out of balance (Washer Repair)
by Ted L 4/5/2018 4:54:34 PM(UTC)
Washer drum out of balance on spin (Washer Repair)
by breckrider 2/4/2018 4:59:32 PM(UTC)
Out of Balance fault when not wobbling (Washer Repair)
by PCS 1/21/2018 9:39:14 AM(UTC)
washer goes out of balance in the spin cycle (Washer Repair)
by stonecoldsob 2/13/2017 2:07:06 PM(UTC)
Whirlpool top load washer out of balance (Washer Repair)
by gvanzant1 12/3/2016 12:10:33 PM(UTC)
Maytag Bravos UL/out of balance issue (Washer Repair)
by Hmbre97 6/28/2016 6:41:01 AM(UTC)
Whirlpool Duet wash basket out of balance, making banging noise (Washer Repair)
by relentless85 1/10/2016 1:30:22 PM(UTC)
performa washer comes out of balance very easily in spin cycle (Washer Repair)
by porterbridges 3/22/2015 6:37:48 AM(UTC)
tub out of balance (Washer Repair)
by doormanrick 5/11/2014 11:07:45 AM(UTC)
Front load washer out of balance, all loads (Washer Repair)
by terri.snider 2/3/2014 1:34:30 PM(UTC)
Washer spin cycle out of balance after replacing basket drive (Washer Repair)
by ms031317 11/16/2013 9:39:08 PM(UTC)
Totally Out Of Balance While Spinning (Washer Repair)
by johndqjr 5/16/2013 4:18:20 AM(UTC)
Washer goes out of balance during spin cycle a lot (Washer Repair)
by bobtx 2/21/2013 11:28:35 AM(UTC)
