GFU125
#1 Posted : Tuesday, December 15, 2015 1:14:03 PM(UTC)
GFU125
Oven shows an F3code within seconds of turning it on. I changed the sensor and checked all the wiring but it still shows the code. Would changing the heating element fix this? Any other ideas?
#2 Posted : Wednesday, December 16, 2015 2:42:34 AM(UTC)
Parts for KitchenAid KEDT105VBL0 Range - AppliancePartsPros.com
I am assuming that you have already removed power from the unit for several minutes when you replaced the sensor and the unit did not reset itself,.
[COLOR="Blue"]Would changing the heating element fix this?[/COLOR]
I doubt it. I cannot be 100% sure as I do not know how they sense an open oven sensor.
I would think they are just looking to see if there is a resistance so the element would not be part of this.
Carefully check where the sensor attaches to the control board for a cold solder joint etc.
While looking at the soled side of the board where the sensor connects gently wiggle the connector to see if it's legs move in the solder. Also check for a cold solder joint on those pins they usually are a duller silver color and/or mat have pin holes. Take a close look at the copper tracks in that area to be sure one of them does not have a crack (open) across it.
A magnifying glass come in handy here.
If all OK the I would say that the problem is on the board.
F3 Code (Oven Repair (including Ranges and Cooktops))
by GFU125 12/15/2015 1:13:50 PM(UTC)
Frigidaire Oven F3 code (Oven Repair (including Ranges and Cooktops))
by gdeanrussell 9/7/2013 6:31:35 AM(UTC)
Whirlpool Gold Oven - E2F3 Code and Broiler Comes on by itself!! (Oven Repair (including Ranges and Cooktops))
by Kentuckypunk 12/11/2012 5:44:12 PM(UTC)
Thermador Dual fuel range oven door locked and f3 code. (Oven Repair (including Ranges and Cooktops))
by mikey77 7/28/2012 7:14:51 AM(UTC)
E2-f3 Code Flashed Onto Display (Oven Repair (including Ranges and Cooktops))
by Todd Reka 6/5/2012 4:24:13 PM(UTC)
F3 code (Microwave Repair)
by cjames 3/22/2012 6:16:15 AM(UTC)
f3 code on maytag mer5730 (Oven Repair (including Ranges and Cooktops))
by fastfreddy 7/12/2011 11:21:58 AM(UTC)
by backatya07 4/16/2011 3:18:47 PM(UTC)
ge oven f3 code (Oven Repair (including Ranges and Cooktops))
by gusjac 2/20/2011 3:43:58 PM(UTC)
GE wall oven F3 code (Oven Repair (including Ranges and Cooktops))
by psquire 12/18/2010 3:28:41 PM(UTC)
Still Getting an F3 Code after heat sensor was replaced (Oven Repair (including Ranges and Cooktops))
by Scott Carlson 8/16/2010 6:39:04 AM(UTC)
oven not heating well, f3 code after replacing temp sensor (Oven Repair (including Ranges and Cooktops))
by jenna99 3/3/2010 11:50:54 AM(UTC)
Spacemaker XL1800 has F3 code (Microwave Repair)
by Cherrystro 10/15/2009 8:07:32 AM(UTC)
Stove F3 Code (Oven Repair (including Ranges and Cooktops))
by batesy 2/22/2009 11:47:12 AM(UTC)
F3 code in Whiprool oven (Oven Repair (including Ranges and Cooktops))
by aranala 2/18/2009 12:10:35 PM(UTC)
