When I hit bake and hit the up arrow to 350, the preheat light comes on for a short time and beeps. The light goes off and beeping continues showing f3 fault. What part do I need, and can I replace it?
THIS FORUM IS DEAD!!!!!!! |
Thanks Denman, Trying to troubleshoot and cannot find the ribbon. I have had the entire console apart. May be looking for a new range.
[COLOR="DarkRed"]Trying to troubleshoot and cannot find the ribbon[/COLOR] Sorry but I do not know what you mean by "ribbon" |
Troubleshooting instructions say to remove the key pad ribbon from the main board and plug the range back in to see if you still get the error code. If it returns, and the sensor checks out, it is the main board. My sensor read close to 1300 on the ohm meter.
Thanks, Fastfreddy
I looked again at your parts and your control does not have a separate keyboard so there is no ribbon cable. I think your unit uses an RS1 control Page 1-14.
Your temp sensor seems a little high but should still run through your oven temperatures would be low as the unit thinks it is at about 200 degrees when in fact it is at room temperature.
Did you check the resistance with it unplugged from the board. This ensures that you read only the sensor resistance and not an alternative/parallel circuit on the board. |
I unplugged the sensor and removed it from the oven to check it. I did this twice and the first time was a little higher. This all happened after doing a self clean. Where do I find the RS1 control Page 1-14 on the internet? Thanks
Sorry for not getting back to you sooner but have been at the cottage.
I was refefring to the manual that I included in the earlier post. |
