tiibee73
#1 Posted : Sunday, November 8, 2015 4:35:16 PM(UTC)
tiibee73
So twice now, I have a melted/burnt wire connector on the direct drive washer motor. This is the same connector, last replaced in August of this year. Any ideas on what is causing this? I attached a PDF of the motor and location of the wire and several pictures from August and today. Any help would be greatly appreciated!!
File Attachment(s):
washer.pdf (463kb) downloaded 5 time(s).
sidfink43
#2 Posted : Tuesday, November 10, 2015 4:29:21 AM(UTC)
sidfink43
Well obviously there is some type of short that is causing a heat buildup that is melting the connection. This is not good.
You could try replacing the motor switch but I would watch things very, very carefully because this could be a fire hazard. If you have any doubts, replace the machine, saving money is not worth a fire.
